engine misfire I'm baffled
chris93
NC
I have a 93 with a 351 and E4OD. It has 178K on it. just did a tune up, plugs, wires, cap and rotor. It ran fine for about a 1000 miles, and now, terrible misfire. I checked the wires and their snug, plugs look good, as do the cap and rotor. It idles fine and first gear is smooth up to about 1800 rpm, as soon as it hits second gear it shakes all the way through the power band, same thing with third and fourth gear. once it is cruising its fine but I'm stumped. I keep up on maintainence, fuel filter is recent, clean air cleaner. What is going on?
Bronc76
how are your plugs wires routed? are they crossing each other?
chris93
chris93
NC
  • how are your plugs wires routed? are they crossing each other?
no, I thought that may be an issue, they are 8mm wires I tried moving them so that the wires for the cylinders wouldnt be next to each other. I
took better note today and as soon as it hits second gear it vibrates all the way through the power band, same with third and fourth if under load. I almost think its driveline vibration but I cant be certain.
Bronc76
could be a bent or unbalanced driveshaft or worn out u-joints. have you checked wheel bearings?
chris93
chris93
NC
Yeah, I was beginning to think drive line related too. the driveshaft doesnt seem to have any play in it so... bearings, I do have almost180k on her so... could be.
chris93
chris93
NC
yup U-joint, no more bad vibes, kind of relieved, beginning to think I would keep throwing money and parts at it and still nothing.
88horse
madera
start it at night and look for sparks jumpin
myine was missing i change the fuel filter and i dont miss no more
watch out under pressure lol
then cycle the key a couple times to build up pressure before u start it
