engine id
viper
i thought my bronco had a 302 as per the info tag by the radiator but when i went to change the distributor i figured out its a 351. where on the engine can i find the id numbers? and where on the web can i find the info i need to id the sucker. also can i lose the egr stuff and change intakes to an aluminum edlebrock? :glare:
gump_black
Ocala, FLorida
i thought that fords had the engine size on top of the air intake manifold
ex. 5.0l or 5.8l
Some say the 5.0 or 5.8 but I have seen some that just say powered by ford . Easiest way to tell the difference between a 302 and a 351W is to measure across the intake . ( top front of the intake from side to side . Its wider than a 302 . ) Without going out to the garage at the moment I loked on the net for measurements and found a site that claims the deck width which I assume is right at the block between the heads lowest point on a 351W is 9 inches and a 302 is 7 inches so you see there is a very noticable difference . If anyone would like Ill break out the tape measure and actually measure a 351W intake and a 302 intake so we know for sure . :D /emoticons/[email protected] 2x" width="20" height="20" />
Staff online
TrishC
