jimko
I figured and hoped someone could tell me if this marking on the rear bearing cap might indicate the engine in my daughter's 78 Bronco. I removed the oil pan and fortunately the crank rotates easily with the plugs out so the next thing is to ID the motor. There was an article I recall saying there would be a stamping on the counter balance weight but there wasn't. The Bronco was given to her and the story was it hadn't passed smog so it was parked a few years ago when still running. The oil was clean and the coolant was clean and full plus it released pressure when I removed the radiator cap. Externally the engine has chewed plug wires and some leads that are missing from rats or mice chewing and there had been a nest on top of the motor. I am cleaning up all the mess and I pulled the starter which wouldn't crank when I jumped it. I also am not sure what Ca smog requires but there was no smog pump in 78 as I recall and just wish that it didn't need to be smogged.
I appreciate all the knowledge on this site!
Jim
Jim
