engine dies
desertbronc
Tucson, AZ
well i just replaced the pick up coil in my bronco because it died and would not start, it ran great for a while. but now the engine will just die all of a sudden, it just started doing this. it will just die, wont sputter or bogg just dies, so i think its an ignition problem, then it will start back up. only happen when im parked or driving slow, anfter the engine is hot. any ideas.
dashwitz
If its possible, check you fuel pressure coming from the fuel pump, sounds similar to an issue i had where a wire shook loose from the fuel pump and the pump would cut out occasionally... usually just long enough to stall out the motor, If i had to guess and the above doesnt work out, i'd definately check into the fuel pump.
