booneable
I have a 72 bronco with a 302 have been rebuilding just about everything I just thought I was done with all mechanical problems but now this. So far its happened three time first time I was driving along about 50 miles an hour and just lost power for around 10 seconds then all was well second time 3 weeks later or so pulled up to a stop light and engine died and would not start until finally I held the gas pedal down while cranking engine and 15 seconds later it started and for 10 minutes or so it gave me issues trying to die and i kept it running but barely then no problem at all ran great now today i pulled up to a stop light and the idle which is normally 1200 was up and down 1000 to 1100 then i took off from the light ran fine for 20 seconds and didnt die until i let off the gas i coasted to a stop turned the key and it fired right away and ran fine all the way home. I have replaced both fuel tanks and all components, new points, new coil, and lots of new wires,and rebuilt the carb. please any ideas im at a loss
