engine build help
thasianhh
i've got a 90 with a 351W. I'm about to put cold air intake, new pulleys, headers and mufflers with conversion to duel exhaust, throttle body spacer, and a performance chip on it.
I was wondering what else should be done. Do i need a new throttle body, or a mass air flow sensor? I'm trying to get a little more horsepower without putting too big of a dent in the wallet. Any advice would be appreciated.
30556[/snapback]
THe mass air won't work on the 90. The best HP/$ or bang for your buck is in a mild camshaft swap. You ca nfind the cam number at any of the major mfg's sites or at fordfuelinjection.com
mbtech2003
cape cod, mass
it will as long u don't go too extreem. mine works fine with the stock computer :) /emoticons/[email protected] 2x" width="20" height="20" />
p.s. dont wast your money on the throttle body spacer. doesn't do any thing. (unless their is a nos port in it @-) not reccomended on a stock engine)
79brnco
