I have decided try to run a Flex-a-Lite-118 (16i have the same problem with mine I have run a flex fan for something like 13 years but wanted to go to an electric fan last year after my fan and radiator had some minor contact. I was in a pond at the time and the fan was just trying to help out by being a proplor. I found a short water pump kit from ford motorsport that gives 1.75 inches more room but have not found out if I have to swap out powersteering and alt brakets. It looks like the pump is from a 94-95 mustang so i need to find one to see if the brakets will work in a bronco. I have found some thin fans from flexalite that might work to. please post any fixes you come up with and I'll do the same
