If the radio is hooked up to the coil. You have to rember . If you are parked and turn the switch on to play the radio. You,ll burn the points up. Unless you went to electronic distributor. I don,t know if it would hurt the distributor. Some one else might know about that. Why don,t you put a junction block on it . Run a wire from the battery then hook the radio up.,but have it set up.The only time juice would be on it.Is when you turned the switch on .Then run you a wire from the junction to the coil. I,d have a in-line fuse for protection though.Hey. I just switched to electrical choke on my 67 with a 289. Not much to hook up to for power. Any pointers would be helpful. Coil is going to radio fuse and vacuum operated wipers. Thanks, hugh
thanks for the info. it starts and runs, but now when i start it up it jumps to about 2000 rpms right away. i am thinking about putting the old carb back on. spent 400 on that street warrior carb. and now the bronco just sits in the garage.
Sounds like mine only it sits outside and the past 3 years I haven,t got to run it yet because one thing after another and its got full coverage. I,m thinkin and hopein when I do it get straightened out,. I,ll get in it and take her for a spin and know it is lega. Still hopein.Good luck to9 you also.thanks for the info. it starts and runs, but now when i start it up it jumps to about 2000 rpms right away. i am thinking about putting the old carb back on. spent 400 on that street warrior carb. and now the bronco just sits in the garage.
I think I read something about those carbs being bad and the company was no longer in business.Sounds like mine only it sits outside and the past 3 years I haven,t got to run it yet because one thing after another and its got full coverage. I,m thinkin and hopein when I do it get straightened out,. I,ll get in it and take her for a spin and know it is lega. Still hopein.Good luck to9 you also.
After it warms up does the idle come down?thanks for the info. it starts and runs, but now when i start it up it jumps to about 2000 rpms right away. i am thinking about putting the old carb back on. spent 400 on that street warrior carb. and now the bronco just sits in the garage.
