EGR Valve
benboy17
If my EGR valve was bad how would I know ,what would it cause my Bronco to do. When I first crank it up the RMP bounch back and forth for about 2 mins.
thanks Ben
yo Ben!
Do you have a Ck Eng. light on?
and you have a 93?
and ck for Codes;
SELF TEST - & DTCs; COMPREHENSIVE; Includes Steps to Clear Continuous Memory & Keep Alive Memory (KAM)Codes; & a list of reasons why a technician may see the MIL lamp lit with no accompanying Continuous Memory Self-Test codes Source: by Steve83
See what codes may come up and post em here or look thru some EGR, EVP, etc Links in my site;
Differential Pressure Feedback (DPFE)
Some bad or dirty parts that can pop on da CEL are:
EGR Tube
EGR Vacuum Regulator (EVR)
EGR Vacuum Reservoir
EGR Valve
EGR Valve Position (EVP)
benboy17
Yes the check engine light is on. Yes its a 93. I replaced the O2 sensor and still the light is on. Ill do the check tonight and see what happens thanks for the info.
barrett86
Spokane, Washington
did you do clear the code after changing the sensor, and does your rpms act erratic like it bounces up and down and smoothes out or just all the time, and have you noticed any loss in pedal, like if you stomp it does it move and does it ever not go if you stomp the pedal.
benboy17
DID THE SELF TEST FOUND OUT ITS MY TP SENSOR. THANKS FOR ALL THE HELP GUYS
Chapin1736
