EGR Valve Check Engine Light
EB Bronco
My check engine light recently started flickering on me when running around 30-40mph and the Bronco can't settle into an RPM. It keeps jumping back and forth all over the place. I brought it to autozone for them to scan and it came up with EGR Valve closed error. I went ahead and replaced the EGR valve and EGR valve sensor. I disconnect the battery while I was doing the work and when I ran it to work this morning it's still doing the same thing. I'm going to get this light tested today at lunch. Could the tube that connects to the bottom of the EGR Valve be clogged and be causing the problem or can something else be going on and tripping the EGR Valve check engine light?
Roger
sreaminbronco
Dallas
Hey Roger i had the same problem and i went ahead and replaced the whole thing you know the valve sensor and the pipe and it stopped coming on.
Bigone96
Vandenberg Air Force Base
Roger
19694[/snapback]
Rodger I also had the same problem I agree with screaminbronco just replace it and it will go off. Also it is an easy swap and descently cheap. Barta
Wihill
