I just looked at mine it looks as if you bolt the seat into the cab floor. I reached underneath and there is a box directly underneath where the seats bolt so there is NO WAY to get a nut on the bottom of the cab floor.on a stock front passenger seat do you use studs or bolts on the back mounts. where it mounts too the floor, just took out some high back's that did not work need to know to put it back in order... Thanks
mine is a 66. my passanger seat is bolted in the front only, the back part of the seat has metal framing that is about 1inch by 1.5inches that acts as the support, laying against the floor. it folds and tumbles, with the help of a hinge system nothing complicated, just the metal framing bolted to the floor and a tab with a bolt through it mounted solid to the seat I looked on the rear of the seat and it looks as if the weight of the passenger keeps the seat "down" but no studs.what year is your bronco, mine is a 74, I don't have a box blocking the undercarage, what I can't rember does the passenger seat not only fold in half but does it flip foward the front mounts are hinged, that is why I was thinking the back mounts were just studs and not bolted down, I would apperciate a reply as to what your does. Thanks jats
the box I'm taking about looks like its some sort of support for strength nothing "hacked" in or added.
mine bronco is 95% original only missing the bumpers, fiberglass doors, front turn signal, cigarette lighter... little stuff
