E40D Transfercase issue
PlumKrazy
Groton Ct
Well for starts here are the truck detils 92 Bronco 5.8 E40D I am looking for info help about the push button 4x4 when I got the truck it did not work so first I checked the motor to see if it worked it did so I replaced the switch in the dash no luck did some pokeing with a test light still nothing from the switch to the motor so I replaced the 4x4 control in the passanger side kick panel and now the motor at the T-case wont work at all cant seem to find a motor that fits the E40D the motors I find at parts stores and BroncoGraveYard have the pig tail and conector with them but the E40D has what I asume is the speed sensor that is in the same pig tail. Any help with is or maybe a T-case that is not push button with be any help
