E40d auto tranny problems ?
xplosiveg06
hey guys i have a 94 bronco and i have a few questions regarding my transmission which just started randomly acting wierd
when coasting like at 20mph holding the gas steady, the truck will somtimes randomly downshift into first or second and i have to let off the gas for it to go back into its normal gear (so its like it has a super sensitive kickdown and will shift whenever it wants)
- also when i put it into reverse, it lowers the rpms into like the 500rpm range and makes a loud clunking sound.
is my tranny on the way out? is there any way to fix this without a rebuild?
bluefordcat
SOUTH DAKOTA
Sorry ! But yes it does the E40d Tranny is built like a tank usually bullet proof Find a trust wory transmission man & have they check it out
1994 Bronco loving IT great machine
bidibronco
Norfolk Va
My 94 did that at one time, thought "oh ***** more money for a tranny now" Before I did the tranny I had blew out my rear end so I had to get a new one. When I got the new rear end (well junk yard new anyways) I opted to get a new speed sensor for it and it cleared up my problems... Maybe something you can look into...
is the E4OD Transmission Control Indicator Lamp (TCIL) Flashing? iif so... post again with info...
by a
<a href="http://fordfuelinjection.com/?p=13" target="_blank">DIY
Self Test & Connector Location & pics, Bronco & Ford BEST PROCESS WITH DIAGRAMS!
Source: by Ryan M (Fireguy50) at fordfuelinjection.com </a>
X
xplosiveg06
is the E4OD Transmission Control Indicator Lamp (TCIL) Flashing? iif so... post again with info...by a
hmm i will try the self test this weekend. the odd thing is i let the truck sit for a few hours, and now the truck is shifting like normal now ?!?
yo, ok, if it gets nutZ again and TCIL Flashes, try self test; could be a few simple and rel. cheap fixes, such as:
Sensor, Water Intrusion of MLP-TR Sensor TSB 95-2-12 for 89-94
Source: by Ford via miesk5 (Al M) at comcast.net; esp. after runnin' thru heavy rain, creeks, rivers or hi tide @ da beach (don't ask 'bout this adventure...lol) or prev water sports resulting in iffy term connections, etc.
btw, Check fluid level and condition...
GL!
seansz28
