Door Panel Fasteners
cjbronco
Jersey Shore
I took out all of my interior panels and padded them for some noise reduction. Im having a problem trying to find the right fastenerst that slip back onto the back of the door panels. Does anyone know where I can find them at? I've tried all the local pep boys and napa ect.. but no luck
Check locally to see if you have a body shop parts supplier or go to a body shop and take one with you. I liberated some from a couple of junkers but you have to be careful that you don't wreck them when removing them. Hmmm a lot of them's :rolleyes:
Say, another thing you can do about sound deadening is to put self sticking sound deadening panels inside your doors on the outer skin, on floor boards and on the rear wheel wells. Also some of that sealed cellular foam insulation padding on against the inside of the quarter panels.
I have used both, in several vehicles, and they work quite well :) /emoticons/[email protected] 2x" width="20" height="20" /> . It won't sound like the inside of a Lincoln ;) /emoticons/[email protected] 2x" width="20" height="20" /> but there is a definate difference and the insulation helps keep heat out in the summer and heat in in the winter.
The stick on panels stop the metal from vibrating and creating noise. You don't need to cover the entire surface, just a couple of locations in the door, one in each foot well and a strip on each wheel well.
CACTUS JACK
West Texas
Any auto store like AutoZone, Advance, O'Reillys etc. should have the "cone-like" plastic door fasteners. Look for one of those HELP! displays.
CACTUS JACK
West Texas
Y'know, I took apart my wife's Toyota Solara door panels this weekend and I think the plastic door fasteners from a Toyota will work with a FORD and I like the design better.
audie.a
16158[/snapback]
The local ford dealership where i live has them.....I have bought plenty of them
audie.a
Wihill
