I have a 1974 eb that I have had latch and opening issues. I have taken all the rods and replace the outside handle and door latch. I still am not able to push the outside button in far enough to unlatch the door. I have tried the adjust the rod to the handle but cant get it correct. Any information would be greatly apreciated
Also, may have a bushing(sleeve) that is either worn enough or missing to let the rod bind up. Could be the aftermarket handle is just not gonna work correctly.
You probably need a sucker…I mean an assistant…that is willing to stand on the outside and push the button whilst you look at the linkage movement. Lol.
Lastly, look at your striker post. I replaced the striker post on a previous one (‘72) because of sticking latch. If the post gets worn enough, it will kinda bind up on new latch assembly.
You may find any or some combo of these is your culprit. Hope this gives you some avenues of opportunity for correcting the issue.
Randy
