I'm looking for a vacuum diagram. There are two lines that go from passenger side exhaust. I know they go to back of carb, but where? I think I got the lines that come off the air cleaner hooked up correctly. Also, just curious if anyone knows where the catalyst protection temp. sensor wires go, or is there really such a thing?
Original motorcraft carb and airfilter bowl, it does have a carbon canister. As far as the air pump, it doesn't currently have one but the alternator has a double pulley and there is a bracket above the alternator. Is that where the pump should be? I'm assuming since its a '76 that it should have one. I'm trying to rebuild it back to original.
