Can wheel well covers for a 96 fit on a 93? I'm just wondering since my father has had a new set of those in his barn for yrs and never put them on his bronco.
as far as the body is concerned the 92 to 96 bronco's are identical, the only things they changed in those years are the on board computer systems from EEC-IV to OBD-II,
Do you mean the plastic type splash shields that are attached to inside of 1/4 panel? Two on each side of the Bronco? (3 small screws and one bolt/nut to bottom of 1.4 panel for section behind wheel & 3 screws and one bolt/nut to section in front of wheel)
or the steel Inner Rear Wheel House that are spot welded to the 1/4?
They look like the metal ones in the picture but these ones r plastic. Basically what I was thinking about is my bronco only has the single shock set up where as my fathers has the dual set up for the front and since those are like that, it had me wondering if the size and indentations in the parts match onto my bronco.
