Donkey-Driver
- Joined
- Sep 6, 2016
- Messages
- 1
- Reaction score
- 0
So a coupe of weeks ago I installed a new HEI Dist this was due to the fact that my 83 Dist. wore out and no one has a replacement one. Even Ford Mo CO says good luck. My old one has no wires at all going to it nor does it have any advance or adjustment. I have never seen this before. Granted I havent had a lot of contact with older fords. Anyway. I am taking it my 1983 Donkey has a Flat tappet cam in it and the New Dist I was sent what I see now is a steel Gear on it. I find this now to be a bad thing. I was driving down the highway humming along as my truck was running great getting better fuel milage then ever when I heard a backfire from **** followed by a few dozen more while traveling at 65. I got off the go fast pedal asap coasted to a stop. Pulled the dist. cap and turned the truck over using the solenoid behind the battery. The dist. didnt turn like it should so I reach over and I could turn the rotor by hand. I put the old one in just to see if it would work to get me home, as I didnt remove the Duraspark system. It spun normal for a sec. then does the same thing. I can turn it by hand as well.
I havent checked the cylinders but it turns over fine no funky sounds and no old in the water or water in the oil.
So I have no reference as to what the cam gear looked like but it doesn't look chipped up. Would it just wear the gear out.?
Also after checking to make sure I have not grenaded my engine or bent anything in the valve train.
Since I have a stock engine 2 Barrel carb and all the smog equipment. I do plan on at sometime going to a EFI setup
What CAM should I go with. I live in Denver so thin air is real. I do go into the mountains a lot.
Thanks in advance for any info
Chris
Chris
