1996 PCED On Board Diagnostics II A
SECTION 6A: Pinpoint Tests
TB: Transmission Control Switch (TCS)/Transmission Control Indicator Lamp (TCIL)
← TB: Introduction
TB1 CHECK TEST VALIDITY
Diagnostic Trouble Code (DTC) P1780 indicates the Transmission Control Switch (TCS) was not cycled during Key On Engine Running (KOER) Self-Test.
Possible causes:
Yes
No
GO to TB2.
RERUN KOER Self-Test to cycle TCS.
TB2 CHECK TRANSMISSION CONTROL SWITCH (TCS) CIRCUIT FOR VOLTAGE
Yes
No
REPLACE PCM. REMOVE breakout box. RERUN Quick Test.
GO to TB3.
TB3 CHECK HARNESS CIRCUIT(S) FOR SHORT TO GROUND
Yes
No
GO to TB4.
SERVICE short circuit. RERUN Quick Test.
TB4 CHECK CONTINUITY OF THE TCS HARNESS
Yes
No
GO to TB5.
SERVICE open circuit. REMOVE breakout box. RECONNECT all components. RERUN Quick Test.
TB5 CHECK HARNESS CIRCUIT FOR SHORTS TO POWER
Yes
No
REPLACE damaged Transmission Control Switch. REMOVE breakout box. RECONNECT all components. RERUN Quick Test.
SERVICE short circuit. REMOVE breakout box. RECONNECT all components. RERUN Quick Test.
TB6 CYCLE TCIL
Yes
No
Concern may be intermittent. GO to Pinpoint Test Step Z1.
GO to TB7.
TB7 CHECK FOR SHORT TO GROUND IN THE TCIL CIRCUIT
Yes
No
SERVICE short to ground between bulb and Test Pin (79). VERIFY a symptom no longer exists.
TCIL turns off when PCM is disconnected. REPLACE PCM. RERUN Quick Test
← TB: Introduction
Possible causes:
- TCS damaged or not cycled during Self-Test.
- Shorted or open harness.
- Damaged PCM.
Yes
No
GO to TB2.
- Key off.
- Disconnect PCM. Inspect for damaged or pushed out pins, corrosion, loose wires, etc. Service as necessary.
- Install breakout box, leave PCM disconnected.
- Key on, engine off.
- Measure the voltage between Test Pin 29 and Test Pins 24 and 77 at the breakout box while cycling the TCS several times.
Yes
No
GO to TB3.
- Key off.
- Breakout box installed, PCM disconnected.
- Disconnect TCS. Inspect both ends for damaged or pushed out pins, moisture, corrosion, loose wires, etc. Service as necessary.
- Measure the resistance between Test Pin 29 and Test Pins 24 and 77 at the breakout box.
Yes
No
GO to TB4.
- Key off.
- Breakout box installed, leave PCM disconnected.
- Measure the resistance between TCS keypower at the fuse panel (ohmmeter positive probe) and power side of the TCS vehicle harness connector (ohmmeter negative probe).
- Measure resistance between Test Pin 29 at the breakout box and signal side of the transmission control switch vehicle harness connector.
Yes
No
GO to TB5.
- Key off.
- Measure the resistance between Test Pin 29 and Test Pins 71 and 97 at the breakout box.
Yes
No
TB6 CYCLE TCIL
- Cycle the Transmission Control Switch (TCS).
Yes
No
GO to TB7.
- Key off.
- Disconnect PCM. Inspect both ends for damaged or pushed out pins, moisture, corrosion, loose wires, etc. Service as necessary.
Yes
No
