dash board
wtfdissux
Buffalo, NY
think so but not really sure how about from a 93 into an 88 or inside door skins from a 93 into an 88 (changing doors too)
snowman74
Oklahoma
Looks to me like 1987-1991 dash is substantially different from pre 1987. Don't know if it would fit without major mods. Same with 92-96...major changes in styling. Because of very minor body changes, I wouldn't think the interior dimensions would be much different, but the mounting systems for the dash boards are very different. I don't think the door skins will work either. 1987-1991 are different from 1992-1996...but I've never tried to change those out. LMC truck has some great pics in their catalogues that break down the interior and exterior parts. You can buy aftermarket interior components from them, as well as exterior. I've purchased door seals and tailgate seals. They are all good quality...but I can't speak for their dashes or door skins.
Snowman74 :)>-
wtfdissux
Buffalo, NY
any idea if the doors would be bolt in or do I need the change the inside skins am planing on putting the e4od trans from the 93 into the 88 so will need the collumn at least for the overdrive button so might change the entire interior if needed the newer is in great shape the older is well... nuff said
Motormouth2025
