Crude dude
I recently installed a new set of coil springs in my 70 Bronco with a Dana 44. The coils that I took out were the same manufacturer but there were slight differences in the coil such as the bottom of the coil had no cuts on the end and the new ones do have the end edge cut off at an angle. The old coils fit real tight in the bottom spring cup and the new ones do not even fit down in the cup because thay are slightly too large in diameter. I figured that I would install them and let the weight of the Bronco push them in but they still didnt seat. I heard back from this reputable business that sells the spring that there are 2 different types of coil spring cups available for the Dana 44 and I need the other style. Anyone ever hear of this? I know there is another style that has a different bolt pattern for the 2 bolts that hold the cup to the radius arm but supposedly they are identical in diameter. I called around and one shop suggests that sometimes you have to grind the coil spring to make it fit, another place said to leave it and that it is fine that way. The coil spring doesnt seat in the cup but almost on top of the cup. Anybody have this same issue?
