Okay...where can I buy a Motorcraft heater core for my 1987 Full Size with a 302? I can't find it on Napa, Drivewire, RockAuto, Jegs, Summit...etc. What's the deal?
Any help would be appreciated.
Snowman74
http://www.trademotion.com/partlocator/ind...amp;catalogid=1
HEATER CORE, Bronco 87-91 $85.11 $63.83
E9TZ-18476-B or E9TZ-18476-A
ask your friendly Ford dealer parts person to match or beat this price
Rock Auto has aftermarket mfgrs.' cores, I do not who is the OEM for Ford though, guessing it could be Modine which is now marketed by Proliance;
http://www.pliii.com/productcatalog/hotcat/index.asp
Make: FORD
Core Size: 7 3/4 x 7 x 2
Inlet: 5/8
Outlet: 5/8
OE Number: E9TZ-18476-B, E7TZ-18476-A
& they are under "Heat & Air Conditioning
https://www.rockauto.com
or;
http://www.ryderfleetproducts.com/cgi-bin/....jsp?oid=126006
by AirSource
Specifications in inches
Height - 7
Length - 7
Width - 2
Inlet - 5/8
Outlet - 5/8
Application - Ford F150-350
OEM Number(s) - E7TZ-18476A
forgot to add that I cut the heater hoses off, @ firewall to make it EZier to remove; of course, new hoses is good idea
check the drain for the heater box - drain is mounted low on the fire wall of the engine compartment of the vehicle - is best serviced from under the vehicle. When the drain becomes plugged moisture from the A/C system and rain water will back-up and spill into the passenger's compartment
& while you're at it
Leaf & Debris Build-Up Location in 80-96 Blower Motors/Ducts/Resistor by STUPID
http://fullsizebronco.com/forum/showthread.php?t=54077
