Yo Nate,
Forgot to mention that itis probably listed as a relay in all data.
Starter fender mounted relay is an electrically operated "switch" used to connect the windings in the starter motor to the battery. The relay consists of a coil, plunger and contact disc. When the coil is connected to battery power through the ignition switch, it becomes an electromagnet. The magnetic force draws the plunger into the coil core. A disc connected to the plunger contacts the relay terminal, completing the battery to starter.
Starter Solenoid is the device mounted to the starter especially in later years.
It performs two functions. It shifts the starter drive pinion into engagement with the flywheel ring gear and connects the starter motor to the positive side of the battery.
The drive pinion is shifted through a lever which is connected to the solenoid plunger. The electrical circuit between the starter B and M terminals is closed by a contact disc which is also attached to the solenoid plunger. The r
