Harleyjasondavidson
Was going to change the thermostat and noticed the neck has a bunch of what looks like vac lines/valves. What gives? Is there supposed to be something connected here?
Im hitting the junkyard friday to hopefully find some wiring harness parts and rear glass switches, tempted to hunt a normal filler neck.
Will be changing the thermostat and temp sender while flushing the system. Will a neck without all this BS cause problems?
