code 44
jeffm
peru ill
i tested my 89 bronco 5.0 and it said code 44 what do i have to replace it to fix it i know it has something to do with the air control or something like that i tested my idle air control valve and thats good i dont know what else to look at if anybody has any idea please let me k now thanks
BroncoJoe19
Jeff,
I checked my Haynes and it says that code 44 means Secondary Air inoperative:
Perform Air pump, valve, valve vacuum and soleniod checks.
I hope that helps.
joe
Jeff,I checked my Haynes and it says that code 44 means Secondary Air inoperative:
I hope that helps.
joe
good job Joe!
Also
DTC 44 (KOER) - Right Thermactor Inoperative - The thermactor system injects air into the exhaust ports in the heads downstream from the valves. Air is supplied from the smog pump through tubing and the TAD/TAB valves to a copper pipe between the heads on the firewall side of the engine, and ultimately to the exhaust passages. If your smog pump is disabled, or your disconnected the tubing (most likely rusted out; get new tubeing from NAPA, etc or PCI) or blocked the thermactor holes in the back of the heads, or if the TAD/TAB valves are bad, you will get these codes
Secondary Air Injection (AIR) System Diagram, 5.0L Source: by Steve83
ok, my pc isn't opening more Links now; see Location Links for tad/tab, etc. here
http://www.broncolinks.com/index.php?index=416
PCI, Inc. - exhaust parts & accessories, air check valves, stainless steel flex tubes for DIY EGR tubes, A.I.R., Catalytic Converter, EGR tubes, etc.; w/Ford part numbers - order their catalog - very helpful tech person!!!! their products are also sold by NAPA, etc.
http://www.pciinc.com/index.cfm
J
jeffm
peru ill
thanks for the help i have no cat so the pipe is no longer on the cat so its just hanging there i guess i will have to get a new cat for it to see if that helps and again thanks for the help
79brnco
