Clicking in the front end
gungho
I just replaced the brake pads on my 93, I had to replace the caliper and rotor on the drivers side. Now i have a clicking noise that stops when I apply the brakes. It is only coming from the drivers side. I took the brakes off and realized that i had not put the clip that holds the inner pad in place on. I put it on and the noise is still there. Any Ideas? thanx for the help.
G
gungho
what do you mean by the hub slightly turned? And where is the speedo cable in the front end, i thought that the speedo cable was in the tranny
broncoheaven
Baltimore MD
Check the splide pinns for the caliper, Mine did the same thing after a brake change and one of the pins were ***** out a little. And yes the speedo cable is in the tranni. not the front end, durr...
G
gungho
the splide pin is what holds the brake caliper on? Because if that is what you are talking about, they are brand new
mbtech2003
cape cod, mass
23397[/snapback]
i had the same noise on mine check your auto locking hubs make sure the shims are in correctly!! and if they are make sure the hubs arn't bad their expensive so i reccomend switching to "WARN" manual hubs best of luck!! :D /emoticons/[email protected] 2x" width="20" height="20" />
