check engine light
nine milly
Horsham pa
ok heres the problem runs fine i dont feel a miss.. when im driving when i get to about 1200-1500 rpm the check engine light will flash as soon as the trans shifts it goes off
nelbur
When the check engine light comes on, a code should be remembered by the CPU. Yours is newer than mine so someone else will have to tell you how to check codes on your truck.
here is a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
Run it around to heat the engine up and shift thru all gears incl Reverse. Then turn off all accessories/lights, etc.
Do Key On Engine Off (KOEO) portion first.
Look Codes up in my broncolinks.com site using the new Search function.
And Post em here according to:
KOEO
KOER
Are all Emission Components in-place? And all vacuum lines in-place and no leaks; ck under dash too for HVAC hoses and vac motors for blend door, etc.
Forgot to mention soon in your profile, include your year, engine, trans, Xfer case & locking hub type (auto or manual) and any major mods such as body or suspension lift, etc. or in any question post. You'll get more accurate replies
btw; how did the Frame issue go?
Ford644
