They are the same, the difference is the motor stands(frame bracket)and there location. If your thinking about putting a V8 in place of the L6, you will have to cut off the stands and replace them with the ones from Bronco vendors.
http://broncograveyard.com/bronco/i-10510_...2_351w_pair.htm
scroll down on this one
http://www.wildhorses4x4.com/17.asp
I think the measurements come with the mounts, but be sure to ask when ordering.thanks for the info. you don't happen to know the measurements on the placements or is it better to hang the engine then mark the spots?
