Changing Gauges
NeCrO4
Farmington, New Mexico
Anyone know if it is possible to change from a instrument cluster with no tach (i have right now) to a cluster with a tach and is it pretty easy? are there any sensors i would have to buy and where would they mount? Im asking this because i wanna change my faces gauges to white with a blue glow but cannot seem to find any gauges without a tach. cause i got my HVAC controls changed now wanna get the cluster to match
bidibronco
Norfolk Va
Not 100% with the Bronco, your Bronc' looks like a 92-96? I know in my 99 ****** (damn brakeless thing at the moment) I got a cluster with a tach and it went in with nothing changed in the wireing. If you're getting it from the junk yard test fit it on another one. Also, take your speedo out and put it in the "new" cluster if you can so your milage is correct.
fordsohc46
fordsohc46
searcy, arkansas
it should bolt in no problem. i swithced clusters on my 97 f150 and every thing worked. your factory harness should already have the wire for the tach.
NeCrO4
NeCrO4
thanks guys for the help ima try it and ill post the results back here with sum pics and maybe a tech write up on the new face gauges
90windsor
channahon
it might work. it worked on my dodge no problem. but then again totally different brand. my bronco came with premium gauges so i never needed changing.
