changing front ends
broncguy101
On my 88 bronco custom how hard would it be to change the front skins to a 92 throu 96. And is anybodyselling theses skins or know of where i could get me a set pretty cheap? Thanks for the help.
Cl10racer
Pueblo West, Colorado
I did that to my '81. I did the fenders, hood and grill to late model skins. All from autofb.com. It has turned out nice. As soon as I put the skin back on I will send you pics.
I started a thread a while back about switching the front end from an 89 to a 92. Theres some pics there but i got busy and that project got put on the back burner . Last week I had a deer run full tilt into the passenger side front of my bronco again destroying the warn enforcer bumperbut this time also destroying pretty much everything on the passenger front so I have to finish this swap now . I have collected all the peices and have the body shop painting the hood filler peice ( between windsheild and hood ) and the rock guard ( between grille and bumper ) So as soon as these are back I will continue the thread with more pics . You pretty much have to have an entire front clip even the core support is different and you also need the hood filler panel . You then will have to do something with the wires harness up front the 87-91 have only 2 light housings and the 92-96 have 3 so I think theres goona be some splicing going on yet but not sure . On the warn enforcer bumper they look cool but they dont enforce shit both of them folded right up and a new skin for them is $400 and the plastic wrap around trim is $69 each . Probably the last time for this one and Ill make a copy of it in 1/4 inch plate see how the deer like that . :D /emoticons/[email protected] 2x" width="20" height="20" />
TrishC
