Change over from automatic to manual
Cole Hamley
I have a 79 bronco had a 400 c6 automatic trans. Im changing to 390 4 speed and the marriage conection from my transfer cace to the new 4 speed dont line up it has 6 holes instead of 4 like I need. what do I do im 17 years old and this is my first big project on my dream truck. some body please help me?
davids78bronco
fabricator extraordinaire
central Oregon
Why are you doing this? THe 400 is a perfectly good engine. While the 390 is badass in itself, there's quite a bit of work involved, to fit an FE engine in a truck that wasn't built to hold one.
Worst case senario, find a Tcase adapter. It really should be that easy. Just make sure it's the same length, as there are two different lengths offered for the Bronco
C
Cole Hamley
32567[/snapback]
yes it is a good motor but I like the 390 and I hate the automatic. can I just get a trans and tcase out of a old 4speed bronco and put in mine?
jgvabronco
You're on the right track getting an already married 4-spd and t-case. Keep the bell to the FE, and that should line up to the front of the trans. If you have a good case already, all you really need is an NP-435 or T-18 out of any 70's 1/2 ton Ford 4X4, or any 3/4 ton or 1 ton Ford 4X4 from 77-79. But now I gotta say it too. You are in for a ton of mods to put an FE in the Bronc for no gain. Stay with the 400. Btw, you may just need the t-case adapter since it doesn't sound like you have the tailshaft housing on there. If the spline count on the output has 31-splines, and is around 10" long, that is probably all you need. But it must be a 4WD 4-spd, not a 2WD 4-spd or the tailshaft will not be right.
stevedave
