silicon_bronco
I know this is not Bronco talk but any recommendations for a CB. I want one for my Bronco and don't want to spend to much..
thanks for the help..
Best thing to do is to ask a truck driver! I know a few but they're all out driving right now!!ya that's what i thought. did some looking around on the web and found pricing from $45 - $229. So you are right you get what you pay for.
thanks..
23945[/snapback]
For real radio range and power you should consider getting your amateur license. Then you have access to repeaters, thousands of frequencies, radios with a wide range of capabilities like computer links and automatic mapping, and typically 100 watts output compared to a CB's 4 watts and 40 channels. You are also freed from listening to a lot of trashy talk because the amateur service has federally enforced rules for on the air conduct. Many amateur radios are built to military specs, which means they can take a terrible beating off road and keep on working. The down side is you do have to study and take a test, the license is good for 10 years, and radios begin at about $150.
Good luck and have fun. BTW I ran an old Lafayette 23 channel in a Blazer for years and never had any trouble with it./emoticons/[email protected] 2x" width="20" height="20" />
23954[/snapback]
