wdetzi
Old School
- Joined
- Jan 11, 2006
- Messages
- 36
- Reaction score
- 0
I could really use some help understanding or fixing my problem!
I just installed my rebuilt 302, starts and runs fine when cold (has a stock 2 B carb). The timing is set at 12 degrees BTDC. After the engine heats up to normal run temp, the idle becomes erratic and will usually stall out. After that it's virtually impossible to start, and the only way I can get it to start is to hold the accelerator to the floor and when it does finally start, puffs of white smoke pour out of the pipes until it's at it's normal idle speed. When the engine is shut down after it stalls, I can hear the gas "boiling" in the carb and vapor is coming out of the throat. Sure would appreciate any help or insight anyone can give me on this problem.
Thanks
PS: The carb is original, but has been rebuilt with just an off-the-self rebuild kit (gaskets, seals, accelerator pump, etc.)
Thanks
