Hehe, I did forget about that part
/emoticons/
[email protected] 2x" width="20" height="20" />
Sorry
/emoticons/
Pull the plugs and look at their tips.
They will have very dry puffy looking soot on them if it is running rich.
(If you can afford a couple of sets (plugs) or just want to scrub them clean for the rest of the checks, I reccomend it.)
Find the two idle adjustment screws on the carb. (Usually you start with the screws run all the way in (gently!!!) and backed out 1 1/2 turns.
Verify that is where the screws are and if not, get them like that, in gently, then 1 1/2 turns out.
If they already were like that, then turn them in (both screws the same amount) about 1/8 a turn, reinstall the clean plugs and start the engine, letting it get to normal temperature again. ( in is leaner, out is richer)
You guessed it, pull the plugs again and look at them
/emoticons/
If they are looking more normal, then you are very close and can make the final adjustments to the idle screws with the engine running (idle) just remember that too far in or out will make the engine stumble, if you do that, just back them both out till it runs smooth again.
As long as the jets are not too large for the engine, you can correct the problem like this.
If you can't get the problem corrected with the idle screws adjustments, then you'll need to pull the carb apart and make sure the floats are adjusted properly and evenly for both floats(edles go from 1" to 1.25" from the carb upper to the top of the floats, if I recall correctly..) and pull the jets to see what size they are and quite possibly getting several sets of smaller jets so you can get the size correct. (might take a few jet changes if this is the case)
A 302 and a 600 cfm is a great combination, very strong when set up properly, so the big issue is just fine tuning the carb. (I had a 65 stang with a 289 and a 600 cfm holley, when I got it set up properly I scalded every vette in Va Beach with it
/emoticons/
[email protected] 2x" width="20" height="20" /> )
