Carb For 300 6?
Desert Donk
The truck is an 85 Bronco with a 300 CID 6 1BBL carb.
My original carb was rebuilt by a friend and the rebuild job lasted as many years as it did prior to the rebuild. My friend had been killed in a motorcycle accident so when that carb needed work I bought a rebuilt one from NAPA. That was not that long ago, a couple of years now and already it is not so great these days. Whenever I go off road and over rocks much larger than a basketball the engine quits from the jiggle. Not sure if it shuts fuel off or floods it for a moment but I think it is a piece of junk. On pavement it works fine and the fuel mileage is fine.
New carbs are $800+ from Ford. Any idea what kind of Carb I can get that would give me at least stock emmissions? Emissions is a big deal here, I don't want to have by truck yanked off the road. Heck it's only a 1bbl so I would not think anyone makes a fancy performance thing.
As a side thought, would anyone suggest upgrading to fuel injection? I think Ford injected the 4.9L 6 in 86 or 87 but not sure. Is it doable? Thanks!
billybroncojr
MI
I haven't had much luck lately with NAPA rebuilds, I won't buy another one. You should start looking for an injected 300, they are actually fairly common. I got a 91 150 in a trade with an injected 300. It ran great. I ended up selling it for $300 just to get rid of it. Fixing the carb would be cheaper but if you are set on the 300 injection is always nice.
Later,
Jeff
hawk2100n
Wants Overdrive
hey, go to autozone. i bought the carb listed below for around $400 brand new. the motorcraft was $80+ an i didnt like the prevous carb. im shure you could get a 1 bbl from autozone or somewhere similar for like 250-300. also check LMC truck. im shure they have new or rebuilt ones for good price.
D
Desert Donk
Thanks, I just recieved the new LMC truck catalog and they do have rebuilt there for the 300 6 but I did not see a new one. I guess my question is, is it safe to get a rebuilt from anyone? I have not asked as Autozone or Checker Auto if they have new for the 6 cyl. For some reason I worry that selections for the 6 are limited because there may not be as many of those engines out there. I think most broncos were sold with V8's. So what I might find is very little new and mostly rebuilt. I always thought NAPA was good with parts but I am gun shy on rebuilt carbs now.
hawk2100n
Wants Overdrive
hey desert donk, remember that bronco wasnt the only truck with a 300-6. this was also a popular engine in the f-150. the bronco is basically an f-150 from the doors forward so there should be no difference for that aspect. napa's parts are usually built for low cost. i dont know what LMC's rebuilts are like but you have other options like edelbrock and holley. by the way, the carb that i mentioned that was $80 dollars more was rebuilt. mine that i bouught was new. there are plenty of carbs out there for you bronco. :D/
D
Desert Donk
Thanks Hawk. I knew they were in F150's too, a friend of mine had one. But believe it or not these are the only two I have ever seen. So I assumed that they were not popular except in fleet vehicles. And those get such high mileage they don't stay in the gene pool long. :) /emoticons/[email protected] 2x" width="20" height="20" /> I'll see what I can find out about something new, I believe the one that is on there is a Carter.
79brnco
