Can someone tell me where the fuel pump relay
Brian
Catskill Mountains of New York
Hello,
I've been having problems with my Bronco's fuel system for some time. The fuel pump wouldn't shut off so I would disconect the battery wire when I parked her. Then some times when I reconnected the battery, the fuel pump wouldn't go on. So I would wack the tank with a stick and the pump would start hummin. Well the other day wacking wouldn't get the pump going so I wacked harder. The full tank started leaking and still no pump. all my gas leaked out at Wally world and I had to flat tow my Bronco home, first time she ever let me down.
Today I replaced the tank and the fuel pump. I found a bad pin on the positive side of the male/female connector [my bad connection]. I got all done and turned on the key and still no hummin. I need to know if there is a fuse and where is the fuel pump relay.
Thanks
Brian
firelt90bronco
Ask me about my job
northeast
There is a black box next to the air filter box, under it are the relays and the box has each named.
redneckpunk
Hopkins michigan
It is on the drivers side there is a rectangular box connected to the air filter. There 2-3 relays in there the one closest to the firewall is the fuelpump relay. Now your best bet is to go to the dealership and get a new pigtail and re wire the whole relay. What happens is the connections get a lot of corrosion and the wires break ( especially on a bumpy road at 2:30 in the morning ). It is a real common problem with broncos and f-150s . By the way AutoZone does not sell the pigtail its only like 5 or 10 dollars at the dealership.
Brian
Thanks for the replys.I found the relay clearly marked in the day light. The relay and conductors connecting it where good and corrosion free. But I couldn't get the fuel pump to start. I had power to it also. I ended up using a jumper wire to start the pump and once the pump had pressure then I reconnected the relay and I'm back in bussiness.
Thanks again.
Brian
79brnco
