bronco lean?
BroncoAddict
Okay i've gotta 74, been working on putting duff's ultimate 3.5. Just got the rear done. But i've got a big problem, My bronco is leaning to the left in the rear :(( . I've heard of the bronco lean but that has to do with the front, right? Checked my measurements, welded everything exactly how it said. Will this settle out when the springs get broke in? Any help will be appretiated.
There's a test but it's a bit of work.....swap the rear springs. If it still leans the same direction, it's obviously not the springs.
BUT FIRST, was it level when you started..? If so, set the front frame rails on "even" jack-stands with front the same height as the back. If it levels out, the prob. may be in the old front suspension.
What did you weld... the shock hoops..?
Are the body pads in good shape..? Tire press. up..?
BroncoAddict
BroncoAddict
It was level when i started. I'll try the sring swap. Had to weld the new back shock mounts. First thought maybe they were twisting the axle diff ways if they were off. It may be in the old front maybe I'll get it done and it will level out right :huh: . Thanks for the help.
BroncoAddict
BroncoAddict
It is the old front you could really tell when i got the back tires back on :) /emoticons/[email protected] 2x" width="20" height="20" /> . Thanks for the help. I'll post some pics when i get the lift done and spray paint her flat black.
79' Buckin Bronco
