Brake Rotor Discard Thickness
jmartin7
specification for front brake rotors on a 1989 Bronco? I just bought the Bronco and performing my own inspections prior to taking it in for a State of Maryland safety inspection, which is required for a two-year registration. Thanks for replies.
Ziggy
Riverside, Ca
Check a Haynes or Chilton manual as they normally list them in there. If not, ask at your favorite auto parts store, if they are good and know what they are doing, they will share that info with you.
Broncoholics
Broncoholics
Washington State
Its stamped on the side of the roter somewhere. Take a wire brush and get the mud and dirt off it and look for the numbers. Then measure it with a gauge or go to the part store and they will measure it for you and let you know. Best thing is get friends with a guy in a brake shop and use them until the warp! :D /emoticons/[email protected] 2x" width="20" height="20" />
J
jmartin7
The rotor is clean and I can't see it stamped on there anywhere, and the Haynes manual I have only provides a location to place the micrometer for checking the thickness...no discard thickness info provided.
If they have ever been turned down, replace them. If in doubt that they are safe, like they look a little thin or scored up, replace them. After all, it's you but that is at stake. They are not hard to replace. :D /emoticons/[email protected] 2x" width="20" height="20" />
guilhermeknob
