I put one of the extreme power brake booster kits from jeff's on a 71 bronco (disc front, drum rear). Finally got the truck together enough to start it and drive it. Seems like it takes a LOT of pedal effort to get this thing stopped. Brakes are bleed correctly, fluid amount ok, new brakes all the way around, drums adjusted properly. Anyone know how much vacuum should go to it? Thats the only thing I can figure is going on.
