broncogordon
- Joined
- Sep 9, 2012
- Messages
- 5
- Reaction score
- 0
Anybody know how to remove body molding off a 73 Bronco?
Hey BG,
Get a wide plastic scraper from Home Depot. Get one kinda stiff, but it must be plastic. If they are glued on, squirt a little "Goof-Off" on the edge and let it sink in. ( try it on an inconspicuous area and see that it doesn't remove the paint).
Use the scraper to get an end pulled up. After it starts I have found they get easier to pull off. Just squirt the Goof-off on as you pull, and take your time.
If they are the kind that are snapped in. Get the scraper under the top or bottom and gently pry up.
Good Luck
Hey BG,
Good Luck
I appreciate you taking the time, I will tell you how it goes, Thanks again, Gordon
