wilcom
Heres the problem;
replaced the stock 302 manifold with a Eldebrock with thier gasket set. Hi temp caulked around the water ports etc like the install sheet says. fired her up and she ran great for about 10 minutes. Test drove her and noticed the water temp climbing from the normal 190 to over 230 degrees and engine started running rough. Shut her down immediately and checked the engine oil and, yup, water in the oil. Had her towed home and removed the manifold. Obviously the water leaked in the engine valley and down to the crank. Couldnt really find out why, the gaskets and caulked look fine other than being ripped up when I took them off.
Any way, I replaced them with a new set of Eldebrock gaskets and cleaned the manifold and intakes on heads. And reinstalled. I torque the manifold to 25 ft lb....ooops, thats what the Bronco eng manual says because I it was not on the instructions with the Eldebrock...which later I found out to be 12-14 ft lb.
Carnked her up again and let her warm up and after 7 minutes I noticed steam vapor coming from the left side exhaust ( I have dual Exhaust) and a small amount of water dirpping from the pipe. Tasted it and yep, it was anti freeze.
Ok, so here is the question;
Do I immediately assume that I blew a head gasket or is it possible I craked the new Eldebrock manifold by torquing it to tight and one of the walls in the tunnel ports in it cracked where water is running through and into a exhaust port on the head. I pulled the first 2 plugs and they were both clean...didnt do the last 2 as the engine was to hot just then. Water in radiator was low by a quart or two also.
I would like to know some of your opinions before I remove the manifold again. I was told by Eldebrock techs that a mechanic could do a pressure test on the engine or something to see. Not a cylinder test but an engine pressure test.....never heard of that one.
Also something I noticed that I never noticed before was that while truning the engine over a few times (eng was cold) that the pressure in the radiator was quite a bit when I released the pressure release on the radiator cap. May or may not have anything to do with it. Also how come both engine blocks have a water port in front and in back and the stock and Eldebrock manifold only have on on each side in front....the back 2 are blocked.
Need some help from my Bronco Friends
