You have a 1992 Bronco, correct? BTW, I am da Typo King! weally!
when turning on one circuit (by means of the Multi-Function Switch (MFS), turn signal/ws wiper washer, flash to pass, switch) it causes another to come on partially, check the ground for the lamp that was turned on first. This is caused by current going thru da bulb filaments & finding a ground for the other lamp...."
Ground Locations in 92-96; "...Haynes manual. They list 10 separate grounds... A-J. A. Starter mounting bolt B. Right front of Engine compartment near the battery C. Lower left front of engine D. Right front of engine compartment on upper radiator support. E. Left front of engine compartment Upper radiator support F. Bottom of cowl panel G. Rear of left fender apron H. Behind bottom of right cowl panel I. Left rear corner of cargo area near rear lamp assembly J. Under center rear of vehicle on rear cross member..."
Source: by Haynes via BroncoJoe19 (Joe) at Ford Bronco Zone Forums
One Turn Signal Lamp Inoperative
Damaged miniature bulb.
Damaged indicator flasher.
Open circuitry.
Individual Turn Signal/Flasher Lamp Inoperative
Open circuitry.
Damaged multi-function switch.
Turn Signal Lamps on Continuously
Short to power.
right front turn/park is at G101 at RH (passenger side) side of Radiator support
http://content.chiltonsonline.com/content/images/WD/Ford/177/WD_Ford_177528.pdf
left front turn/park is @ G100 at LH side of Radiator support
http://content.chiltonsonline.com/content/images/WD/Ford/177/WD_Ford_177521.pdf
check for corrosion etc
Wiring Diagram in 92-96 Bronco & F 150; for lighting only, Multi-Function Switch (MFS), turn signals, head lights, hazards, etc.
Source: by seijirou at SuperMotors.net
Grounds in a 92 by Chilton
Left turn thru connector C431
right turn thru C432
and then to splice S406 left & S405 right respectively then to Ground G100
diagram by Mikey
Here is the rest of the ckt back to MFS etc.
to C406 Left and C405 right
joins again @ Splice 401
& S400
then to C205 (firewall connector)
then to C202
Here is conn pin-out diagram for this
Firewall Connectors C202 & C205
Here is the diagram showing C202 & C205 location in engine bay by Mikey
Turn, High & Low Headlight Dimmer, Flash-to-Pass, Hazard, Multi-Function Switch (MFS) & Brake Light Testing & Wiring Diagram in 92-96; "...the MFS testing is done with connectors disconnected; it's strictly an internal test of the MFS;
Miesk5 NOTE; Brake Light & Turn, High & Low Headlight Dimmer, Flash-to-Pass & Hazard CKTs are a Feed-Through Circuit in Multi-Function Switch (MFS)
Turn Signal Removal Video in a 94; MIESK5 Note, Suggest Right Clicking this Hot Link & Open in New Window
Source: by pfun41 at youtube.com
