bearings transmission
bronco 351w
holland
Hello
Can any one of you tell me what type of bearing is in a rat ah2 transmission on the output side. On the bearing that i remove where no number so i hope that you can help me
greetings from holland
Helloooooo Holland..!
Un-clear....are you referring to the outputshaft (bearing) on the transmission itself...or, is the transmission still attached to the adaptor for the transfer-case...& it's that bearing in question..the one on the end of the adaptor?
And --- "ah2" ...where is this designation from..?
bronco 351w
bronco 351w
holland
Hello bully Bob
I referring to the outputshaft (bearing) on the transmission itself .
i find out what type of bearing was used so i don't need any help more on this moment.
and about rat ah2 is on the type plate.
but thank you very must
79' Buckin Bronco
