Bad miss just off idle
KJEfting
Ogden, Utah
The old bronco is missing pretty bad just off idle and it's definately lacking in the power department. I recently replaced the plugs, wires, cap and rotor. I pulled the plugs and all are still golden brown. It seems like it only misses between 800-1300 RPM. I should rephrase that... It only "feels" like it's missing between those RPMs. Any ideas?
-Ken
Roadkill
Killeen, TX
Was it missing before you put the new parts in? Or was this preventive mainenance? Start with the basics, make sure all the plugwires are fully seated and that you didn't mess up the firing order. (not trying to insult your intelligence, :)>- any one can make a mistake). When you changed the wires, did you route them back the exact same way? If not, spark could be jumping somewhere along the way.
