scroller bill
- Joined
- Aug 3, 2006
- Messages
- 61
- Reaction score
- 0
Hi all. I hooked up the auxiliary light on my bronco the other day. I wired them through a relay and used the low beam wire from my dimmer switch to activate the relay. What I want to do is have a seperate switch in the dash area so I can turn just the auxiliary lights on with out the headlights. On the relay, if I tap off the same terminal as the low beam triger wire is attached and run that wire through a on/off switch and to a power, will that power wire feed down to the dimmer switch and turn on my low beams when I turn the switch on? I hope I'm explaining it clearly. I'm thinking that I may be better off using a seperate relay for my auxiliary lights only switch.
Let my know what you think.
Bill
Bill
