AOD shift lever leak
87BRONCXLT302
Looks like my tranny sprang a leak. Does anybody know the oil seal p/n? Also - Can this seal be replaced from the outside and is there a special tool required?
Thanks in advance for any tips or advice you may offer!
Yo 87,
AOD Shift Shaft (Linkage) Seal Replacement by entity-unknown @
http://broncozone.com/topic/24324-aod-shift-shaft-linkage-seal-replacement/?do=findComment&comment=127092 in an 87 AOD
Sources:
http://www.oreillyauto.com/site/c/search/AT+Shift+Shaft+Seal/03242/C0071.oap?year=1987&make=Ford&model=Bronco&vi=1105883
National - Automatic Transmission Shift Shaft SealLine: NAT | Part # 7929S
  • 3 Year Limited Warranty
  • Seal
  • Ford C6 3 Speed Transmission
  • Ford AOD 4 Speed Transmission
  • Housing Bore (In): 1.063 Inch
  • Material: Nitrile
  • Quantity Per Vehicle: 1
{Click Info Button for Alternate/OEM Part Numbers}
$4.82
At http://www.rockauto.com/m/mobilecatalog.php?parttype=8648&tab=search
Call napa, advance auto, etc.
"I bought the seal 4 years ago and had a look when I had the pan off changing the internal trans filter;
See the shaft at the far right of the photo ? Nearly halfways up ? That's the shaft it's gotta go on. I thought about removing the outer linkage, but it didn't seem like that was enough, but I'm no expert.
I've been well into a 727, but this job looked too ugly for me. One of those jobs where I could well F#@& it up so bad a slightly wet seal and a once a week drip would seem like nuthin'.
Here's a pic of the toothed plate it runs through, if you want to print these off and take the pics to a trans shop for an estimate;
Tell em' you want an internal filter change "and {yawn} while you're in there, how's about changing this?".
My leak never got worse, so I'm livin' with it until you pioneer this one for the rest of us
Hope that's some kinda help, good luck"
by Sixlitre
"I had to replace mine 3 months ago. I got mine from a transmission shop here in Orlando. Here's the number if you want call them. There are actually 2 seals on that shaft. One is for the TV Valve & the other is for the shaft. Alternative Transmission - 407-877-3664, maybe they will mail you one or can give you a correct part#. I went in & told the guy I needed the shaft & TV seals for an AOD & brought them back within a minute - knew exactly what I needed."
by MrWP819300
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Keep each post limited to one issue,as you just
 did.
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
Here are some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) @ http://www.revbase.com/BBBMotor/Wd
Wihill
