anything more?
oktogo
york sc
Hey i have a 89 fullsize with a 5.8 efi i was wondering i have a comp cam with a k&n intake and throttle body space headers. is there any more i can do before a start messin up my efi like a intake manifold or the whole kit? and is a new set of heads worth it? like alot more power?
Miss Kitten
alberta canada
what gear ratio are you running in those diffs?
if you change out the gear ratio you'll have alot more power too
Greggk
if you did a cam, the heads, intake and exhaust are holding that cam back. just get the edelbrok efi intake, a decent set of heads, **** a set of gt40's are better then what you got, and headers, bassani y pipe and 3" exhaust and your truck will be MUCH happier
oh yeah and change your gears to 4.56's and you should be set to rock and roll
Oldhenry1
