:-& Hey everyone I'm new here. I've been trying to fix this antifreeze leak for the last 8 months on my own. The problem is that the antifreeze puddles up on top of the timing chain cover on both low point creveses. It does'nt leak when in park, just when driving (of course so I can't see where it is coming from). I've never experienced this much difficulty with coolant systems. Anyways, I was wondering if anyone has had problems with antifreeze oozing up through the back seal of there timing chain cover. I already replaced the water pump and thermostat (after that I took them both off again to reseal them), then I replaced all the hoses on the upper part of the engine and also replaced the thermostat housing. Just today I did a pressure test and while the system was under pressure, I washed off the antifreeze puddles on the timing chain cover and then watched the green crap come back out of now where??????????????? Could it be possible for antifreeze to come out of the timing chain cover? Oh, I have a 95' Bronco XLT, 5.8L. Thanks for reading this lengthy sob story.....
