walkercreekbronco
- Joined
- Sep 15, 2004
- Messages
- 143
- Reaction score
- 1
I am putting the power steering from a 74 into my 73. The 74 had an auto transmission while the 73 has a manual tranny.
Before I put the column from the 74 in, I need to replace the signal switch and bearings. I also want to put the manual switch housing on (for looks).
The 73 has already been converted to floor shift, so that should simplify things.
The problem is, the wiring connectors at the bottom of the column are different. What style of signal switch do I need here? JBG lists 3 or 4 to choose from.
Are there any other potential problems I might have with this swap?
