yo Chris
See my Questions and some info in your other post here @
http://broncozone.com/topic/24625-help-please/?do=findComment&comment=129202
also, a Scan Tool Won’t Initiate Self-Test Due to Poor Grounds, Corroded Wiring, etc
by Jermil
If the ground wire works, do the Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
A helper is good to assist in reading Codes; best is to take a cell fone vid and replay it.
Some basics;
Visual Check
Battery is fully charged
1.Inspect the air cleaner and inlet ducting.
2. Check all engine AND HVAC (under hood & in /under dash) Vacuum hoses for damage, leaks, cracks, blockage, proper routing, etc.
This is by Ford for the E4OD
Shift Concerns: No 1st Gear In Drive, Engages In Higher Gear
Possible Component
Reference/Action
215 — ELECTRICAL ROUTINE
Powertrain Control System
•Electrical inputs/outputs, vehicle wiring harnesses, powertrain control module, shift solenoid 1, shift solenoid 2, transmission range sensor
•Run On-Board Diagnostics. Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis./// this is the self test for codes
315 — HYDRAULIC/MECHANICAL ROUTINE
Shift Linkage (Internal/External) or Cables, Transmission Range (TR) Sensor
•Damaged, not connected, misadjusted
•Inspect and service as required. Verify linkage adjustment as outlined. After servicing linkage, verify that the transmission range (TR) sensor is properly adjusted. Refer to In-Vehicle Service in this section.
Main Controls aka Valve Body (miesk5 Note, inspect the connector and its wiring
•Bolts not tightened to specification
•Retighten bolts to specification.
•Gaskets damaged, misaligned
•Inspect for damage and replace.
•Shift solenoid 1, shift solenoid 2 stuck or damaged
•Refer to Electrical Routine No. 215.
•Solenoid regulator valve, 2-3 shift valve, 3-4 shift valve, D2 valve — stuck, missing, misassembled, damaged
•Inspect for damage. Service as required.
•Air bleeds for S1-S2 circuits missing
•Inspect for damage. Replace case.
•Wrong components used in rebuild
•Verify that proper components were used. Service as required.
Mechanical
•Band servo, clutches damaged
•Refer to proper disassembly procedures in this section.
For diagnosis related to a specific gear, use Transmission Tester to determine gear Refer to the following routine(s) for further diagnosis
No Shift 1-2, Routine 220/320
No Shift 2-3, Routine 221/321
No Shift 3-4, Routine 222/322
Reverse Ring Gear
•Damaged gear lugs to reverse carrier
Low One-Way Clutch
•Damaged, misassembled
•Inspect for damage, proper assembly. Service as required.
